Simple 1D viscous flow in Lagrangian co-ordinates |
July 19, 2023, 15:48 |
#21 |
Matthew
Rep Power: 4 |
In LeVeque's book, he does this to obtain a very very simple system of equations that may be solved via the method of characteristics. However, my thoughts are how to solve a mathematically idealised system of equations.
July 19, 2023, 15:49 |
#22 |
Lucky
Rep Power: 66 |
The length of your elastic rod is governed by your BC's, which you have completed omitted. And that is just the start because you have to come up with compatibility conditions.
Even in cartesian, you have no measure for the length of a rod if the BCs aren't at fixed locations. Aside: I can't say I have ever met anyone that has confused a Dorodnitzjn transformation for a Lagrangian, and certainly never a mathematician. |
July 19, 2023, 15:59 |
#23 |
Matthew
Rep Power: 4 |
I didn't specify any boundary conditions, correct. The condition for the length is given by differentiating the total mass in Eulerian co-ordinates. The boundary conditions are essentially only there to fill in the boundary points.
lagrangian co-ordinates |
Lagrangian particle tracking in periodic flow | jabeken | STAR-CCM+ | 2 | April 11, 2021 10:07 |
Problem with FsiFOAM simulation of beams (2-4 beams) in a steady simple shear flow | Aliiiii | OpenFOAM Running, Solving & CFD | 1 | February 27, 2019 12:26 |
Search for a simple compressible viscous code | nimav | Main CFD Forum | 0 | June 13, 2013 02:59 |
Compressible viscous flow newbie: when NOT to assume incompressible, non-gas EOS? | Srh | Main CFD Forum | 0 | April 19, 2013 02:12 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
