LBM Compressible and incompressible simulations |
July 19, 2023, 23:04 |
guhao
At present, a slit flow is used to test the ability of calculating compressible flow of standard BGKLBM. We know that the standard LBM equation is used to calculate weak compressible flow. Then, I set up a slit of 10 micron *500 micron and simulated it with a lattice of 20*1000. The medium is air, the upper and lower walls are partially rebound, and the inlet is given 1.5 times atmosphere. When the outlet is given to 1 atmospheric pressure, the compressibility effect is very obvious. However, there is a big difference between the results of my LBM and those of Fluent, but the maximum velocity value does not reach the limit of 0.3Ma. When the pressure difference is reduced, the gap between LBM and Fluent is decreasing, so I want to know whether it is because the pressure ratio is too large. Beyond the computing power of standard LBM, or for some other reason, thank you very much! The velocity cloud image of the LBM is shown in the figure below.
lbm high pressure |
[GUIDE] Switching from incompressible to compressible simulation | gabrielfelix | OpenFOAM Running, Solving & CFD | 2 | September 3, 2021 12:45 |
Compressible vs incompressible SGS model! | zhangyan | Main CFD Forum | 10 | June 4, 2016 04:39 |
difference between incompressible k-epsilon model and compressible k-epsilon model | yhy20081016 | OpenFOAM Running, Solving & CFD | 3 | January 19, 2016 07:49 |
Compressible -> incompressible. | Jinwon | Main CFD Forum | 6 | November 23, 2007 21:07 |
Compressible vs. Incompressible formulations | Fernando Velasco Hurtado | Main CFD Forum | 3 | January 7, 2000 16:51 |
