Kolmogorov scale in less than fully developed turbulence |
July 31, 2023, 21:25 |
Rep Power: 3 |
If the flow is less than fully developed turbulence (and for the sake of argument let's say considerably less), then is the cascade of energy able to "grind down" to the Kolmogorov scale? Or is there perhaps a larger scale at which all of the kinetic energy has been dissipated? Or is the cascade always able to make it to the Kolmogorov scale regardless of the level of turbulence (assuming that there is turbulence). I would think it would be a function of Reynolds number per Lumley's statement in his 1992 paper:
" Note also that, for low Reynolds number, the time shrinks to a very small value, since the energy is dissipated at essentially the same wave number where it is produced, while for high Reynolds number it goes to 2L/u." (page 207, J.L. Lumley Phys. Fluids A 4 (2), February 1992.) Here L is the large scale eddy size and L/u is the turnover time of the largest eddies. |
July 31, 2023, 21:53 |
Lucky
Rep Power: 66 |
What happens at low Reynolds numbers is, there is no longer separation of scales, no energy cascade, and the inertial length scale disappears. But there is always a dissipative scale, though it might not exhibit the -5/3 law.
July 31, 2023, 22:09 |
Rep Power: 3 |
When you say there is no longer separation of scales, the inherent assumption is that the large scale eddy size is the same (for this statement). If so, then that means that the smallest scale must be larger and therefore the smallest scale is not the Kolmogorov microscale (even though a Kolmogorov microscale could be calculated??). If what I am saying is true, it probably follows that there will always be a Taylor microscale (even though it's link to physical reality is circumspect). That's because the Taylor microscale would approximately mark the beginning of the dissipation range whereas Kolmogorov scale marks the end.
July 31, 2023, 22:43 |
Lucky
Rep Power: 66 |
There is no inherent assumption that the large eddy size is the same, they simply vanish.
You can debate if you want to consider the largest scales becoming smaller or the smallest scales becoming larger. However, the only remaining scale is clearly fully dissipative. It would be even weirder to consider that the integral scale or taylor scale suddenly becoming dissipative when it is not behaving like an integral scale nor a taylor scale at all. Or you can just bring in Occam's razor Kolmogorov himself studied such cases of transition (including sub-critical transition) where there is only a dissipative scale. Even in the time of Kolmogorov, it was considered that the Taylor microscale is the first to disappear. You need to be careful what you are calling Kolmogorov scales. If you define Kolmogorov scales as the scales that strictly obey the -5/3 law then Kolmogorov scales never exist. |
July 31, 2023, 23:12 |
#5 | |
Rep Power: 3 |
August 1, 2023, 03:43 |
Filippo Maria Denaro
Rep Power: 71 |
In an alternative way, the Kolmogorov lenght scale is that one for which the local Reybolds number is 0(1). Therefore you can think it depends only on a characteristic velocity.
When you have only a dissipative range you cannot use the -5/3 scalinig for comparison. |
August 1, 2023, 11:28 |
#7 | |
Rep Power: 3 |
August 1, 2023, 13:46 |
Lucky
Rep Power: 66 |
Dissipation is negligible as a mechanism of turbulent transport when compared to production. Dissipation is obviously not negligible compared to itself.
dx/x may be a small but dx/dx is O(1) Local Re>1 is the threshold at which the inertial terms overcome the dissipative effects. It is not a statement that dissipation suddenly disappears. |
August 1, 2023, 13:51 |
#9 |
Rep Power: 71 |
The kolmogorov lenght is just the end of the dissipation. Let us see the dissipation in the physical space, that is mu*S:S. You will see that dissipation depends on the characteristic Re number. Do not take the figure in the textbook to be general, it is at Re_lambda=600, have a look also at Fig. 6.21 and 22 at higher Re. |
August 1, 2023, 14:49 |
#10 | |
Rep Power: 3 |
PS: I GUESS the answer is that E(K) is defined as the energy per wave number. So if the wave number increases, then the ordinate would have to go down. Last edited by rdemyan; August 1, 2023 at 14:57. Reason: Possible Answer |
August 1, 2023, 15:26 |
#11 |
Rep Power: 71 |
Energy transfer in real turbulence happens with a degree of correlation. A spectrum with equal density would correspond to a white noise, a totally uncorrelated signal. |
August 1, 2023, 21:39 |
#12 |
Lucky
Rep Power: 66 |
E(k) is the energy at the wavenumber k. The energy per wavenumber k would be E(k)/k
Honestly you should plot P(k) versus E(k) versus D(k) to answer your question, then it would be clearer. You are making grandiose statements based on P and D but the entire time you are looking at E. |
August 1, 2023, 22:05 |
#13 | |
Rep Power: 3 |
Is P() the production of energy? I haven't seen that term before. But isn't the production at only a very narrow band of low values for k, which is near the integral scale and then I presume it would drop off to zero as the energy starts to get transferred in the inertial regime?? |
August 1, 2023, 22:56 |
#14 |
Lucky
Rep Power: 66 |
I clearly wrote that k is wavenumber. If you decide to use another symbol, that's up to you.
If you have a heat transfer background like I do, k is also thermal conductivity. For physicists, k is boltzmann constant. These arguments are pedantic. You are putting words in my mouth. I completely disagree that E(k) drops because k is increasing. That is an observation, not an explanation. I encourage your continued reading. Take your time in understanding turbulent transport. There is no rush. You keep flip flopping on whether dissipation is everything, dissipation is nothing, and here again. There is no need to grasp for straws. |
August 1, 2023, 23:06 |
#15 | |
Rep Power: 3 |
E() = TKE/ Source: Slide 26 in http://www.lcad.icmc.usp.br/~buscagl...er_09-kolm.pdf |
August 1, 2023, 23:13 |
#16 |
Lucky
Rep Power: 66 |
Again, I clearly wrote that k is wavenumber. What really is the difference between E(k) where k is wavenumber versus E(banana) where banana is wavenumber? I am not responsible for your misconceptions.
k is Boltzmann constant, one of the six fundamental constants. If you want to nitpick I can nitpick too. If you want, I can stop using symbols and only write in a wall of text. |
August 1, 2023, 23:17 |
#17 | |
Rep Power: 3 |
August 1, 2023, 23:26 |
#18 |
Lucky
Rep Power: 66 |
I simply don't agree with your statement that E(k) drops because k is increasing. Please don't attribute that to me.
Is there an empirical formula for the wall shear of fully developed turbulence? | CarbonO2 | FLUENT | 0 | March 26, 2023 22:20 |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Patch fully developed velocity and turbulence profile over full domain | Teumde | FLUENT | 2 | June 29, 2015 13:47 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Kolmogorov turbulence time scale | iko | FLUENT | 2 | July 15, 2008 10:04 |
