LocalPatchInteractionModel for Sliding Mesh Patches in lagrangian solver in OpenFOAM |
August 9, 2023, 13:09 |
Shaik Asif
Rep Power: 6 |
Hi Everyone,
I am running a mixervessel tutorial with sliding mesh approach using NCC. Its a based on particleFoamSolver. I need to provide the LocalPatchInteraction type in cloudProperties file, I provided the nonCouple1 and nonCouple2 as none type. HTML Code:
patchInteractionModel localInteraction; //standardWallInteraction; LocalInteraction; MultiInteraction; NoInteraction; PatchInteractionModel; Rebound; RecycleInteraction localInteractionCoeffs { patches ( outlet { type escape; } ports { type rebound; e 0.97; mu 0.09; } vessel { type rebound; e 0.97; mu 0.09; } stirrer { type rebound; e 0.97; mu 0.09; } shaft { type rebound; e 0.97; mu 0.09; } shshaftRotatingaft { type rebound; e 0.97; mu 0.09; } sparger { type rebound; e 0.97; mu 0.09; } inlet { type rebound; e 0.97; mu 0.09; } nonConformalCyclic_on_nonCouple1 { type none; } nonConformalCyclic_on_nonCouple2 { type none; } nonConformalError_on_nonCouple1 { type none; } nonConformalError_on_nonCouple2 { type none; } nonCouple1 { type none; } nonCouple2 { type none; } ); } Please can anyone help me with this challenge? |
August 10, 2023, 08:17 |
Lucky
Rep Power: 66 |
You are sure all boundaries are specified for a serial case then?
You can try adding a wildcard .* patch entry at the start, this will ensure everything is at least defined Code:
.* { type none; } |
August 10, 2023, 08:21 |
Shaik Asif
Rep Power: 6 |
Thank you for the reply. I will apply this changes and update about the result. Once again thank you.
August 18, 2023, 13:27 |
#4 | |
Shaik Asif
Rep Power: 6 |
Actually this trick did not worked. I am getting following error "ill defined primitiveEntry starting at keyword 'patches' on line 135 and ending at line 182" at line 182 I have .*{type none}. All patches must be specified when employing local patch interaction. Please specify data for patches: nonCouple1 nonCouple2 nonConformalCyclic_on_nonCouple1 nonConformalCyclic_on_nonCouple2 nonConformalError_on_nonCouple1 nonConformalError_on_nonCouple2 procBoundary1to0throughnonConformalCyclic_on_nonCo uple1 procBoundary1to0throughnonConformalCyclic_on_nonCo uple2 procBoundary1to2throughnonConformalCyclic_on_nonCo uple2 procBoundary1to3throughnonConformalCyclic_on_nonCo uple2 procBoundary1to4throughnonConformalCyclic_on_nonCo uple2 procBoundary1to5throughnonConformalCyclic_on_nonCo uple2 procBoundary1to6throughnonConformalCyclic_on_nonCo uple2 procBoundary1to7throughnonConformalCyclic_on_nonCo uple2 procBoundary1to8throughnonConformalCyclic_on_nonCo uple2 procBoundary1to9throughnonConformalCyclic_on_nonCo uple2 procBoundary1to10throughnonConformalCyclic_on_nonC ouple2 procBoundary1to11throughnonConformalCyclic_on_nonC ouple2 procBoundary1to2throughnonConformalCyclic_on_nonCo uple1 procBoundary1to3throughnonConformalCyclic_on_nonCo uple1 procBoundary1to4throughnonConformalCyclic_on_nonCo uple1 procBoundary1to5throughnonConformalCyclic_on_nonCo uple1 procBoundary1to6throughnonConformalCyclic_on_nonCo uple1 procBoundary1to7throughnonConformalCyclic_on_nonCo uple1 procBoundary1to8throughnonConformalCyclic_on_nonCo uple1 procBoundary1to9throughnonConformalCyclic_on_nonCo uple1 procBoundary1to10throughnonConformalCyclic_on_nonC ouple1 procBoundary1to11throughnonConformalCyclic_on_nonC ouple1 Due you have some idea regarding this? |
August 18, 2023, 14:20 |
Lucky
Rep Power: 66 |
Use the wildcard *
August 18, 2023, 14:23 |
Shaik Asif
Rep Power: 6 |
I tried that it gave an error "expected string".
Exact error is --> FOAM FATAL IO ERROR: [15] wrong token type - expected word or string, found on line 0 the punctuation token '*' |
August 18, 2023, 14:48 |
Lucky
Rep Power: 66 |
So have you tried ".*" already or are strings new to you?
I have no clue what system you are using to know if your wildcard is .* or * and string quotes are ' or " |
August 18, 2023, 15:21 |
Shaik Asif
Rep Power: 6 |
Hi LuckyTran,
I tried patches( '*' {type none} ); I got following error : Constructing clouds [0] [0] [0] --> FOAM FATAL IO ERROR: [0] invalid first character found : ' [0] [0] file: /mnt/work/GOFIQ/01_204rpm/constant/cloudProperties at line 185. [0] [0] From function virtual Foam::Istream& Foam::ISstream::read(Foam::word&) [0] in file db/IOstreams/Sstreams/ISstream.C at line 439. [0] FOAM parallel run exiting [0] Then I tried this "*" { type none; } I got following error: --> FOAM FATAL ERROR: [2] Failed to compile regular expression '*' Invalid preceding regular expression [2] [2] From function void Foam::regExp::set(const char*, bool) const [2] in file regExp.C at line 154. |
August 18, 2023, 17:57 |
Answer
#9 | |
Shaik Asif
Rep Power: 6 |
Hi LuckyTran, you were right the correct implementations as you suggested. ".*" { type none; } Once Again thank you very much |
[Other] [cfMesh] Error when creating AMI patches propeller | gabrielfelix | OpenFOAM Community Contributions | 2 | July 5, 2023 20:54 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
