CFD code entirely from scratch using MATLAB for lid-driven cavity flow
Old   August 17, 2023, 15:50
Default CFD code entirely from scratch using MATLAB for lid-driven cavity flow
Chandan Varma
chandanvarma07 is on a distinguished road
Hello everyone,
Inspired by the insightful teachings of Prof. Sandip Mazumder on YouTube, I have constructed a CFD code entirely from scratch using MATLAB for a classic problem: the lid-driven cavity flow. My goal is to implement a co-located mesh approach and harness the capabilities of the SIMPLE algorithm to ensure accurate pressure-velocity coupling. But after running the code, the residuals were blowing upto infinity.
In the early stages of debugging, I closely monitored the simulation's behavior. The initial iteration yielded a promising outcome, with both X and Y momentum well-preserved—a strong validation of my approach. Employing the TDMA method, I've attached an x momentum contour from the first iteration for your reference, exhibiting similarities to patterns observed in heat conduction cases solved by the ADI Method.
However, as I delved further into debugging, a significant challenge emerged: accurately calculating face velocities. It became evident that inaccuracies at this step were rippling through the simulation, affecting pressure source term calculations and subsequently impacting the pressure correction data. Notably, certain cells exhibited discrepancies between the sign of pressure source terms and correction data.
Through careful examination, I've begun to explore whether the absence of appropriate boundary conditions in face velocity calculation might contribute to these disparities. This has prompted a deeper consideration of boundary condition implementation and its potential influence on this critical simulation stage.
To provide a comprehensive view of my progress, I've attached the code I've been diligently working on. Your insights and expertise in reviewing this code would be invaluable in helping me address these challenges.
TIA
chandanvarma07 is offline   Reply With Quote
2D Lid Driven Cavity Flow simulation using MATLAB josephlm Main CFD Forum 4 August 17, 2023 20:36
Patankar CFD FORTRAN 90 Code FVM siddiquesil Main CFD Forum 19 October 25, 2022 05:21
Sample code for SIMPLE-algorithm and solving Lid-Driven Cavity flow test is uploaded Michail CFD-Wiki 14 February 23, 2020 10:26
Matlab code for turbulent flow Karima Main CFD Forum 1 August 11, 2017 10:20
Question about Lid Driven Cavity Flow modeled by FEM msalamih Main CFD Forum 2 March 1, 2014 15:41
