Regarding Ethylene/Air Combustion Simulation in openFoam |
Niyas
Rep Power: 13 ![]() |
Greetings,
I'm currently engaged in a numerical simulation focused on ethylene/air combustion within openFoam version 6. I have a couple of inquiries that I hope someone can assist with: Inside the '0/C2H4 folder, I've come across a certain line. Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 0.1111111; To achieve a 50:50 ratio of C2H4 and H2, is it sufficient to create a new file labeled '0/H2' and specify the H2 content in terms of either mass fraction or mole fraction? Are there any specific considerations or precautions I should be aware of? Your insights and guidance would be greatly appreciated.
Regards, Niyas |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Generally they are mass fractions because transport properties are transported by the mass flux. To be certain, we should look at the particular transport equation being invoked by this solver. And to know what solver it is, you should tell us exactly where you found this dir.
Creating a file called 0/H2 merely creates a file called H2 that may or may not ever be loaded by the solver. Again, tell us the solver. It is apparent that you are unfamiliar with OpenFOAM, you should be cautious of everything, especially yourself! You do not want to be misguided by your own misunderstanding. |
Niyas
Thanks for your reply.
The solver we use is an in-house-based solver but basically adapted from reactingFoam. So, I want to use pure ethylene/air combustion in stoichiometric conditions with N2 as inert, is the below values correct? We'll use the balanced chemical equation for the combustion of C2H4: C2H4 + 3 O2 → 2 CO2 + 2 H2O Here are the calculations: Calculate the Molar Masses: Molar Mass of C2H4 (ethylene): Molar Mass = 2 * Atomic Weight of Carbon (C) + 4 * Atomic Weight of Hydrogen (H) Molar Mass of C2H4 = (2 * 12.01 g/mol) + (4 * 1.01 g/mol) = 28.05 g/mol Molar Mass of O2 (oxygen): Molar Mass = 2 * Atomic Weight of Oxygen (O) Molar Mass of O2 = (2 * 16.00 g/mol) = 32.00 g/mol Calculate Mass Fractions: Mass Fraction of C2H4: Mass Fraction of C2H4 = (Molar Mass of C2H4) / (Molar Mass of C2H4 + 3 * Molar Mass of O2) Mass Fraction of C2H4 = 28.05 g/mol / (28.05 g/mol + 3 * 32.00 g/mol) Mass Fraction of C2H4 ≈ 0.348 Mass Fraction of O2: Mass Fraction of O2 = (3 * Molar Mass of O2) / (Molar Mass of C2H4 + 3 * Molar Mass of O2) Mass Fraction of O2 = 3 * 32.00 g/mol / (28.05 g/mol + 3 * 32.00 g/mol) Mass Fraction of O2 ≈ 0.652 The value is C2H4 = 0.348 and O2 = 0.652
Regards, Niyas |
Lucky
So you have an in-house code that you obtained from someone else but they're unable to explain how their code works? Either your name is GPT-4 or you are a thief!
So reacting foam. Is your YEqn.H the same as the one provided with reacting foam? Namely Code:
fvScalarMatrix YiEqn ( fvm::ddt(rho, Yi) + mvConvection->fvmDiv(phi, Yi) - fvm::laplacian(turbulence->muEff(), Yi) == reaction->R(Yi) + fvOptions(rho, Yi) ); ddt(rho,Yi) and Div(phi,Yi) Yi is your transport variable Your calculations are of course not correct |
Niyas
There is a slight modification.
{ volScalarField& Yi = Y[i]; fvScalarMatrix YiEqn ( fvm::ddt(rho, Yi) + mvConvection->fvmDiv(rhoPhi, Yi) == reaction->R(Yi) );
Regards, Niyas |
combustion, mass fraction, mole, openfoam 6, simulation |
OpenFoam Combustion SIG | dlahaye | OpenFOAM Announcements from Other Sources | 0 | August 14, 2023 11:39 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
Need help for the 2D airfoil simulation using OpenFoam | losiola | OpenFOAM Running, Solving & CFD | 0 | October 10, 2018 10:22 |
Doubts Regarding Performing Combustion Simulation in OpenFoam | DineshMyilsamy | OpenFOAM Pre-Processing | 0 | June 26, 2018 07:39 |
OpenFoam Airfoil simulation - replacing Fluent with OpenFOAM | shereez234 | OpenFOAM Running, Solving & CFD | 1 | November 3, 2015 03:54 |
