Adjustment between two boundary layers in ansys meshing watertight geometry
Old   October 3, 2023, 00:00
Default Adjustment between two boundary layers in ansys meshing watertight geometry
Jose Martin
JMM_UC3M is on a distinguished road
Hi all,
I am creating unstructured mesh using the watertight scheme in ANSYS Meshing, but I am having trouble adjusting the two adjacent boundary layers. Specifically, I would like to control the step transition between them. You can refer to the attached file for clarification. Currently, I only have four cells to work with, but I would like to have, for example, 10 or more. Does anyone know how to achieve this? (The geometry is that of a cylinder with external flow, and I am trying to adjust the boundary layers around the cylinder.)
Many thanks in advance and best regards
JMM_UC3M is offline   Reply With Quote
Old   October 4, 2023, 01:52
Jose Martin
I'm feeling a bit stuck on this point, so if anyone has knowledge about this topic, I would greatly appreciate it. Thanks in advance!
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
ANSYS FLUENT watertight meshing work flow support rajasekhar reddy ANSYS Meshing & Geometry 0 October 30, 2020 07:27
[ANSYS Meshing] Ansys Meshing doesn't import geometry correctly mohsen_23 ANSYS Meshing & Geometry 1 October 1, 2020 02:17
[DesignModeler] Ansys Meshing splits geometry lines Slurm ANSYS Meshing & Geometry 0 March 22, 2017 12:13
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
