about OpenFOAM rigidbody motion lib
Old   January 3, 2024, 06:52
Default about OpenFOAM rigidbody motion lib
dam
pujunhao
dam is on a distinguished road
Hello everyone,
How to get the center of mass of an object when using the rigidbody library.
The log file output only: Centre of rotation,Orientation, Linear velocity,Angular velocity.
dam is offline   Reply With Quote
Old   January 3, 2024, 16:58
Geray
German-A is on a distinguished road
if you don’t know how to do it through the library, just load the object into any CAD and it will calculate the center of mass. If there is a dynamic environment inside the body or the body mass is not constant, then select several stationary states of the object and load it into CAD
German-A is offline   Reply With Quote
Old   January 3, 2024, 20:49
dam
pujunhao
Thank you for your answer, but I need a continuous center of mass motion to calculate his translational motion in all three directions. With CAD, only one moment can be calculated at a time. Can paraview be used to extract this data?
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[FSI] How can I simulate non-uniform and timevarying mesh motion in OpenFOAM ARTisticCFD OpenFOAM CC Toolkits for Fluid-Structure Interaction 4 May 14, 2019 15:40
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 04:27
External management of solid motion (using dynamicmesh) maxou1993 Main CFD Forum 0 July 28, 2015 11:37
