Single phase, gravity, incompressible fluid
Like Tree2Likes
  • 1 Post By sbaffini
Old   January 16, 2024, 11:40
Default Single phase, gravity, incompressible fluid
Hi
Mathematician is on a distinguished road
I read some posts saying that the gravity has no effect on a single phase incompressible fluid since there is no variation of local density.
But if a fluid is at a certain height, the gravity source term should accelerate the fluid downwards, right? If I have a fluid on the moon, the fluid is just single phase, still it's going to accelerate.
Another question; If I have an eulerian incompressible FVM solver, how could I do the simulation lagrangian? (the fluid starts to fall from a certain height and then it reaches the ground, a problem that seems tricky to be solved with eulerian)
Mathematician is offline   Reply With Quote
Old   January 19, 2024, 18:12
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
If we split density in a constant + variable part, the gravity term with the former can be absorbed in the pressure, which means that your whole domain has a base acceleration and resulting pressure gradient, but no relative motion comes out from that.
Relative motion due to gravity, instead, requires non constant density in space.
I try to interpret what you wrote and I guess you refer to liquids falling trough air, which indeed have different densities. Air would fall trough other air only if it is colder (with higher density) than surrounding air
aerosayan likes this.
sbaffini is offline   Reply With Quote
Old   January 19, 2024, 18:23
sbaffini's Avatar
Paolo Lampitella
I have now read some of your previous posts and better understand what you meant.
Vacuum is outside the validity limit of Navier-Stokes equations. Matter moving in vacuum under the influence of gravity is a completely different topic, that only under certain conditions can be retraced back to some form of fluid dynamic behavior.
Old   January 20, 2024, 07:13
Sayan Bhattacharjee
aerosayan is on a distinguished road
I've also seen the continuum assumption break down for partial vacuum, or rarefied gases.
In SU2-Nemo's conference videos for Martian atmosphere re-entry, they say that results from Navier-Stokes are not exactly correct.
aerosayan is offline   Reply With Quote
Artificial wall error in fluent aiden_1995 Main CFD Forum 0 January 9, 2023 14:06
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Single Phase water jet Problem against gravity beyonder1 CFX 5 May 19, 2017 06:14
Fluid passing through a porous medium in three phase doneatlast Fluent Multiphase 0 January 28, 2017 07:42
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
