January 16, 2024, 11:40 |
Single phase, gravity, incompressible fluid
Hi
Rep Power: 2 |
I read some posts saying that the gravity has no effect on a single phase incompressible fluid since there is no variation of local density.
But if a fluid is at a certain height, the gravity source term should accelerate the fluid downwards, right? If I have a fluid on the moon, the fluid is just single phase, still it's going to accelerate. Another question; If I have an eulerian incompressible FVM solver, how could I do the simulation lagrangian? (the fluid starts to fall from a certain height and then it reaches the ground, a problem that seems tricky to be solved with eulerian) |
January 19, 2024, 18:12 |
If we split density in a constant + variable part, the gravity term with the former can be absorbed in the pressure, which means that your whole domain has a base acceleration and resulting pressure gradient, but no relative motion comes out from that.
Relative motion due to gravity, instead, requires non constant density in space. I try to interpret what you wrote and I guess you refer to liquids falling trough air, which indeed have different densities. Air would fall trough other air only if it is colder (with higher density) than surrounding air |
January 19, 2024, 18:23 |
I have now read some of your previous posts and better understand what you meant.
Vacuum is outside the validity limit of Navier-Stokes equations. Matter moving in vacuum under the influence of gravity is a completely different topic, that only under certain conditions can be retraced back to some form of fluid dynamic behavior. |
January 20, 2024, 07:13 |
#4 | |
Sayan Bhattacharjee
Rep Power: 8 |
In SU2-Nemo's conference videos for Martian atmosphere re-entry, they say that results from Navier-Stokes are not exactly correct. |
Artificial wall error in fluent | aiden_1995 | Main CFD Forum | 0 | January 9, 2023 14:06 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Single Phase water jet Problem against gravity | beyonder1 | CFX | 5 | May 19, 2017 06:14 |
Fluid passing through a porous medium in three phase | doneatlast | Fluent Multiphase | 0 | January 28, 2017 07:42 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
