Negative pressure rise across blower
Old   January 31, 2024, 14:51
Default Negative pressure rise across blower
Adam
310toumad is on a distinguished road
So I tried to match blower performance curve with CFD and it generally underpredicted results, however at the free flow condition with the highest flow rate the static pressure rise was negative in the simulation (this was the only data point with negative SP rise).
My BC's were volume flow inlet and static pressure outlet set to atmospheric. How does a negative pressure rise happen? I guess this is the CFD program basically saying, this flow rate you are specifying is "impossible" based on the assumptions being made in the model, therefore the only way to satisfy the volume flow rate BC is to increase the pressure at the outlet in order to achieve the correct pressure differential. All other data points at lower flow rates apparently can be satisfied in the simulation, therefore inlet pressure remains below atmospheric as the suction of blower is enough satisfy flow rate BC.
I imagine if I changed to total pressure inlet and flow rate outlet, the same result would have happened at free flow except this time outlet pressure would drop to negative (instead of inlet pressure climbing). I think of it like another imaginary blower is being placed at either inlet or outlet to aid in pulling/pushing the air through if the BC cannot be satisfied.
Is that interpretation more or less correct?
310toumad is offline   Reply With Quote
Old   January 31, 2024, 18:27
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
A negative pressure rise is a pressure drop and that is exactly what happens when a blower is not doing any blowing. It's basically a very lossy pipe. It is a windmill that is taking energy out of the flow to spin itself. If you want the pressure rise to be 0, then you need to attach a motor to spin the blower.
LuckyTran is offline   Reply With Quote
Pressure fields in FOAM, p field, total pressure, etc. Tobi OpenFOAM Post-Processing 9 March 25, 2022 01:33
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
