Help with grid refinement study - can't get less cells! |
February 4, 2024, 04:45 |
Rep Power: 4 |
I know this sounds bizarre, but I can't actually get a medium or coarse mesh level. I've tried multiplying my sizings by 1.4 initially, and the cell count went from 28 million to 34. I then multiplied the sizings by 2 instead, and it was at just under 30 million. How in the world does this work? What am I doing wrong? I multiplied all the min and max size values for each local refinement as well as the global settings. Prism layer count/growthrate/first height were unchanged.
problem with parallel calculations OF8 mpirun | otaolafr | OpenFOAM Programming & Development | 0 | January 5, 2021 07:33 |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 14:43 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
snappyHexMesh in parallel - FOAM Fatal IO Error | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | August 10, 2012 19:18 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
