Not getting expected fluid flow in a Water drop with contact angle 90 degree, comsol |
February 28, 2024, 09:27 |
Kumar
I am modelling A curved water droplet as a Quarter Circle in a 2d axis-symmetry model with a contact angle equal to 90 degrees. I am using the moving mesh module. I have used the fixed boundary for the bottom of the quarter circle further; in laminar flow physics, I have modelled this same bottom as the No Slip boundary condition. I have not included the gravity. I have modelled the curved surface of the Circle as a Free Surface while the External Pressure is set to zero. But when I run the time-dependent study, I find that the top point of the free surface of water is not still instead, is has some finite flow velocity. I expect the droplet to be still, and there should be no flow velocity.
Please help regarding modelling a stable water drop(no flow) like a quarter of circle with 90 degree contact angle. I have attached the model, adaptive mesh refinement is selected, just simply run time dependent and see the velocity results. |
cfd, comsol, fluid flow, surface tension |
Fluent UDF Mesh Motion Issue: Blade Pitch w/ Respect to Azimuth Angle | recmvp | Fluent UDF and Scheme Programming | 0 | July 30, 2023 15:50 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
wmake compiling Problem with OF1.5 | openTom | OpenFOAM Installation | 4 | May 3, 2009 14:44 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
