moltan metal flow
Old   August 31, 2000, 02:24
Default moltan metal flow
jeyamani
hi
any one could help me to calculate viscosity of molten metal ,i want to simulate moltan metal flow inside the mold using ANSYS-Flotran.
any information regarding above is avilable in web or journels.
thanx in advance
jeyamani.
Old   August 31, 2000, 22:39
Default Re: moltan metal flow
John C. Chien
(1). If we assume that molten metal is liquid, like water, then, the effect of the viscosity can be characterized by the Reynolds number. (2). So, without knowing anything specific, one can still simulate the flow based on the Reynolds number. And later on one can relate the solution to the specific viscosity, temperature, size etc. (3). Why not select some Reynolds numbers and go ahead to do simulations. In this way, you will be able to cover all the temperature range (viscosity range), and the size. (4). By the time you start worrying about the heat transfer, cooling effect, etc..., you already have some ideas about the whole thing. (5). So, simulation is to do analysis in terms of the dimensionless parameters, such as Reynolds number and Mach number.
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 06:44
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
