flow modelling
Old   September 9, 2000, 01:46
Default flow modelling
sameer mohrir
Hello everybody on forum
can anyone tell me what are benfit of flow -modelling
regards
sameer mohrir
Old   September 11, 2000, 11:33
Default Re: flow modelling
Alton J. Reich
We're doing some valve flow modelling for a customer of our's. A $5000 flow analysis has saved them a $50,000 hunk of scrap metal on the shop floor that would not have met the performance requirements of the specification. How's that for a benefit?
Alton
Old   September 11, 2000, 13:54
sameer mohrir
Hello Alton
Means flow modelling are having more benefits in terms of time and cost point of view.
regards
sameer mohrir
Old   September 12, 2000, 06:45
tommy
In certain cases, apart from direct cost involved, the physical situation also plays a major obstacle for going in for real life experiment, like high temp and all. Modelling helps in that.
Old   September 12, 2000, 06:57
sameer mohrir
Hello Tommy Banerjee
Thanks for clarifications. Are you carrying out the experiment like high temp and all.
Regards
sameer mohrir
Old   September 12, 2000, 14:45
Alton J. Reich
I think it always comes down to time and money. Perhaps this is more true in industry than in academia, but I think it is true across the board.
Tools that save time and money will be used because it makes sense to use them. If performing a test can be done in a few days, and for very little money then there is no reason not to run the test.
In the example that I used, running the test would involve quite a bit of time and cost. First the valve parts would need to be cast, then machined. The machined parts would have to be inspected and assembled. Finally the test would be run. That valve design would not pass the required flow at the required pressure differential which would have left the designers with a $50000 piece of scrap.
A simulation could be performed in a few days for much less money to find out the same thing. When the valve is built, a test will still be performed because the specification requires it, however, the valve will meet the performance requirements.
Regards, Alton
Old   September 14, 2000, 03:46
sameer mohrir
Hello Alton
Thanks for giving a practical eg of flow modelling. Can you let me know whether you have carried out such experiment on pumps or turbine.
regards
sameer mohrir
Modelling Supersonic TwoPhase Flow with Phase Change wes OpenFOAM Running, Solving & CFD 9 July 27, 2021 11:05
VOF modelling open channel river flow Matthew Roberts FLUENT 6 July 31, 2009 12:52
modelling blood flow in arteries with starcd sara Siemens 5 April 10, 2007 09:17
Modelling flow around a ship's hull using vof Manoj Kumar FLUENT 0 February 26, 2005 16:22
Basic Multiphase Flow Modelling krishna Main CFD Forum 2 August 27, 2004 08:40
