In the gas-solids flow, the number of particle
Old   September 22, 2000, 14:29
Default In the gas-solids flow, the number of particle
Hung Jung
I am studying about the fundamental of the Gas-solids flow.I have a question about the Gas-solids flow.
1. What is the Mass loading ratio. 2. How to calculate the number of the particle at the inlet passage on the numerical solution.
Old   September 28, 2000, 04:51
Default Re: In the gas-solids flow, the number of particle
Jin Wook LEE
Dear Hung Jung
1. Mass loading ratio(let MLR) is defined as (solid mass flow rate / gas mass flow rate). It is very important parameter. When MLR < 0.2, the flow is called as dilute phase flow and the effect of the presence of solid particle to the gas flow can be neglected. So, gas flow is not affected by the solid particle, whereas the behavior of solid particle is determined by the gas flow. When MLR > 0.2, the flow is called as dense phase flow and the effect of the presence of solid particle to the gas flow should be considered. So, gas and solid particle interact each other. When MLR exceeds unity(1.0), Eulerian-Lagrangin approach might have convergence problem. If volume fraction of solid particle exceeds 10-12%, Eulerian-Lagrangian approach can't be applicable. Instead, Eulerian-Eulerian approach can be applicable. And so on.
2. In general, particlle number at the inlet is your input, not calculated output. So, sorry, but I can not understand your question. If you are Korean(I guess it by your e-mail address), feel free to contact me by 02-3661-6411.
Sincerely, Jinwook LEE
Two way particle coupling in OF 2.0 and the particle reynolds number preichl OpenFOAM 7 February 9, 2012 15:38
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 17:51
Gas flow in vortex tube - LES and grid resolution bernarde Main CFD Forum 1 March 26, 2009 10:50
heat transfer betwen gas and particle eri andika FLUENT 5 December 8, 2003 18:42
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
