October 10, 2000, 00:13 |
the residual
Hi,everybody,
When I program a code to form the body-fitted mesh by sovling the system of possion's equations with Thompson source term,I solve the equations with full multigrid(FMG) and FAS,I find the residuals on each big V-CYCLE level are bigger and too much depend on the size of the physics plane,if increasing the number of the iterations,the residuals decrease too slow ,even not decrease at all finally,WHY?anybody can tell me how to deal with it? thank you in advance |
October 11, 2000, 06:33 |
Re: the residual again
additional,the mesh plotted looks OK.
James |
October 13, 2000, 05:59 |
Re: the residual
hello
How about monitering update(say, delta x/y/z) on each MG-cycle. Compare delta x with the residual on each cycle. This may tell you something. good luck!! T. Matsuzawa |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
