Animation
Old   November 2, 1998, 23:11
Default Animation
Frank Muldoon
I am having difficulty making movies of unsteady flows. My current problem involves two zones. I am able to use Tecplot to animate the zones, however it only animates one zone at a time. Has anyone used software that will enable one to animate X number of zones together?
Old   November 3, 1998, 01:58
Default Re: Animation
Christoph Lund
Yes, you can animate more than one/two zones in tecplot using the tecplot-macros. This is however limited to something about 50 (could be 60, I can't remember the exact number) zones, so it will not do for long-time animations.
The solution we found is as follows:
1) Use a shell-script to do a loop for the number of timelevels you want to process. You will have to provide a single datafile for each timelevel. 2) Within the loop call tecplot with the single current datafile (i.e. in batch-mode). You could use some generic datafile-name if the shell-script will take care of the correct file. 3) Let tecplot produce a single graphic output-file, i.e. postscript or tiff. Again, you can use some generic name if the shell-script takes care of some intelligent naming, i.e. numbering of the data-files. 4) Put all data-files in a single directory. 5) Use some tools like ImageMagick (http://www.wizards.dupont.com/cristy/) to combine all files to a single mpeg-file. As an example, suppose all files are postscript-files. You can produce a mpeg-movie using the commnd "convert *.ps movie.mpeg".
Hope this helps, Chris
By the way, there is a mailing-list for tecplot-users. Consider tecplot-talk@mail.amtec.com
Old   November 4, 1998, 11:51
Joern Beilke
Where are your data from ?
You can try EnSight. It is a good animation software and they also offer a 1 month trial license.
Creating animation through TUI wawa FLUENT 27 November 5, 2021 03:17
Cropping animation spatially smonsch ANSYS 0 September 3, 2009 14:09
Multiblock animation in Tecplot. Simon Tecplot 4 February 10, 2006 10:27
Animation query..newbie qn derick FLUENT 2 December 9, 2005 09:45
Animation in Tecplot ryoga Tecplot 0 February 18, 2002 11:19
