confined jets
Old   December 30, 2000, 05:03
Default confined jets
djemaa
is the model ka ibsilone the most mode to simulated of confined jets
Old   December 30, 2000, 07:43
Default Re: confined jets
Ghanshyam Singh
Currently none of the two-equation turbulence model is good for Jets(free or confined). Though it is claimed that Realizable K-epsilon model is good but claim is only by the others. No one else has tested it (as of I know). Any way, your English looks very very bad. You are from?
GS
Old   December 30, 2000, 08:56
djemaa
je suis de l'algerie je travaille sur un sujet qui traite un ecoulment d'un jet confine dans une machine aide respiratoire , je veus savoir est ce que on peut consedere le comportement de cette jet au bord de l'ejection comme etant un jet libre
Old   December 30, 2000, 12:50
John C. Chien
(1). Even though I had one year French course, I don't think I can read your message. (2). I think, the better approach is to use simple words and symbols to write the message. For example, your question could be written as: Confined Jet, k-E two-equation = best? (3). The answer to the question is : K-E two-equation = all right, but N.E. best. That is, you can start using it, but there are problems related to the results, perhaps higher jet spreading.
Old   December 30, 2000, 12:52
Ghanshyam Singh
Excuse me, I can't understand you. If you can write in English we can discuss.
GS
Old   December 31, 2000, 01:16
Default Re: confined jets"errata"
Ghanshyam Singh
Please read "authors" instead of "others" in the second line of my previous posting. I am sorry for commenting on your English. Mine too is not that good. We write "Hinglish"!!!!! Any way John's idea is good, better begin with k-epsilon model.
GS
Old   January 2, 2001, 04:25
Chetan
Here is an attempt at translation.
I am an Algerian and I am working on the subject of flow of confined flows for a respiratory aid equipment. I want to find out if I can consider the jet at the edge of the ejection as free jet.
Chetan
Old   January 2, 2001, 05:35
djemaa
avez vous deja utiliser le code de calule Team
Old   January 2, 2001, 06:55
Ghanshyam Singh
You have to tell me the aspect ratio, that is the ratio of the diameter(or equivalent diameter)of the confinement to the dia. of the jet. If it is too large then you can assume it as a free jet. Typically, if the aspect ratio is of around 20 or less you cannot assume it as a free jet. Effects of wall will be very much predominant. There is a Non-Dimensional parameter called Craya-Cutret Number. Frequently used to characterize the flow pattern in case of confined jets. I can give you some more details after knowing more exactly about your prob.
GS
Old   January 2, 2001, 08:35
djemaa
le rapport des diametre est inferieure a 20 je te presente mon prebleme je travaille sur un sujet qui traite un ecoulement d'un jet confine dans une machine aide respiratoire , j'utilise le code de calcule appelle Team et je trouve beaucoup de preblemes pour sumiller cette ecoulement surtous ce qui conserne pour une chambre de confinement divergente , je souhaite que vous pourez m'aider, j'ai un manque de documentation qui traite ce type d'ecoulement.merci
Old   January 2, 2001, 09:29
  #11
djemaa
merci
Confined Impinging Jet Geometry furley2372 Main CFD Forum 0 May 31, 2011 20:18
MIXING OF JETS KRISHNA CHANDRAN.R FLUENT 1 September 19, 2007 14:42
TRANSIENT HEAT & BOUYANCY IN CONFINED AIR Carl CFX 1 September 25, 2006 09:48
Summer Course on ''Jets in Cross-Flow'' alfredo soldati Main CFD Forum 1 May 5, 2001 21:34
confined jets hoda Main CFD Forum 2 January 2, 2001 06:47
