Artificial Viscosity
Old   January 9, 2001, 19:04
Default Artificial Viscosity
Girish Bhandari
Can anyone suggest an artificial viscosity reference other than Anderson's book or pressure based artificial viscosity? Thanks in advance.
GB
Old   January 9, 2001, 20:49
Default Re: Artificial Viscosity
John C. Chien
(1). There are two occasions when the word artificial viscosity is used. (2). In density based, transient compressible flow formulation, an explicit artificial viscosity term is added to the governing original equation for stability reason. It has nothing to do with real viscosity at all. But the term added is always of higher order form. It should be called stability improvement term or damping function term. (3). In the pressure-based formulation (or incompressible flow), the lower-order method , such as the upwind method, can be expanded to show the numerical diffusion term or effect. The second-order numerical diffusion term is sometimes called the artificial viscosity term, which exists implicitly through the first order formulation. It should be called implicit numerical diffusion effect, since no additional term is added to the original equation.
Old   January 11, 2001, 09:38
Girish Bhandari
John, I agree on your points. Could you pl suggest a few good references on Artificial Viscosity(damping)? Thanks.--GB
Old   January 11, 2001, 14:40
John C. Chien
(1). I think, the book by Anderson, Tannehill and Pletcher, " Computational Fluid Mechanics and Heat Transfer" is the place to start. (2). The book covers both the explicit and implicit "artificial viscosity" in many places. (3). In most cases, the explicit "artificial viscosity" terms are invented by the author of his method, therefore, you will have to dig out his original paper to see the detailed function. This is another "black art" of CFD. If you don't like his form of "artificial viscosity", you are free to invent your own. (4). It would be fun to watch the passenger of a rocket ship, when you told him that the rocket ship was designed based on your CFD analysis using your secret formula of "artificial viscosity" to stabilize the solution.
Old   January 11, 2001, 15:28
Girish Bhandari
You are right John. Its all right as long as it gives you C olor F ul D ollars.
Old   January 13, 2001, 13:22
John C. Chien
(1). It is interesting to know that "artificial viscosity" did not come from the market side, but rather came from academic research side. (2). In a way, CFD is polluted right from the begining. For those who have to publish papers to survive, they thought they had invented something quite useful. (3). You can say that, most density based formulations containing artificial viscosity, also produce artificial solutions. And at one time, a journal was forced to reject the papers based on first-order method (upwind method), because they thought that the true solution could be found somewhere in the higher-order method domain. (4). Since the free market is free to eat anything , the artificial viscosity will be around for a long time, as long as it is packaged or recycled properly. I mean, you are not going to see " CFD with artificial viscosity" on the label of the package. Most likely, it will be "CFD using well-known method developed by Prof.xyz, from first-class university-abc". (5). Your question is very important, because modern CFD development were largely based on these artificial viscosity effect, first-order mwthod, or limiters. There will be long term and short term effect, so make sure that you know what you are eating. (In some places, dog meat was sold with lamb on the label, as news said in very old country. The lamb label was for the officials, because customers liked the dog meat. It is quite possible that dog meat was the only thing available in the stone age (like CFD with artificial viscosity), and later it got integrated into people's DNA. After that, it became the story in the news in the old country.)
Artificial Viscosity Luiz Eduardo Bittencourt Sampaio Main CFD Forum 12 November 13, 2011 10:21
Artificial Viscosity MAB CFX 1 July 30, 2008 22:00
Artificial viscosity rads CFX 2 July 31, 2006 07:02
artificial viscosity rvndr Main CFD Forum 1 March 2, 2004 10:24
Jameson-type Artificial Viscosity Steve Allison Main CFD Forum 1 February 19, 2003 08:50
