area of triangle
Old   June 1, 2001, 14:27
Default area of triangle
clifford bradford
How do I find the area of a triangle in 2-D if I know the coordinates of the corners?
Old   June 1, 2001, 14:36
Default Re: area of triangle
bronze
use Heron's law:
a^2 = s(s-a)(s-b)(s-c)
a=area a,b,c = side lengths s=0.5*(a+b+c)
(works well for 3-d too)
Old   June 1, 2001, 14:38
bronze
http://www.cs.mtu.edu/~shene/COURSES...06/area-3.html
The method and the code
Old   June 1, 2001, 17:05
Sid
The three vertices are ordered in counterclockwise order, (x1,y1), (x2,y2), (x3,y3). Then,
S=0.5*(x1*(y2-y3)+x2*(y3-y1)+x3*(y1-y2))
which can be derived easily by computing a cross product of a parir (any pair) of the side vectors.
Bye
Old   June 1, 2001, 18:38
clifford bradford
Aha! Thanks.
Old   June 2, 2001, 09:33
Barry
Hi
The very best way to do it is to calculate the cross product using two vectors (sharing the same origen)(one of the corner vertex of the triangle) which forms the edges of the triangle. Half the norm of the resulting vector will give ya the surface area AND by doing so you already calculated a normal to the surface which ye want anyhow. Just make sure your convention is correct, otherwise your normal vector might point in the wrong direction.
Cheers Barry
Problem with reference area alfaben STAR-CCM+ 3 April 21, 2020 09:46
Non overlap area fractions saisanthoshm88 CFX 11 September 17, 2015 18:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Area, triangle, Earth Jon Main CFD Forum 2 April 25, 2005 08:43
