July 15, 2001, 02:19 |
To verify case study
Hello..
I am new for this field.I want some advise for my case study.Now i am testing my source code dealing with ventilation system in the space on the base of turburent flow,steady state. Best regard. Ruengsak. |
July 15, 2001, 15:44 |
Re: To verify case study
(1). You can always run some simple test cases where the test data or solutions are known. (2). For the specific configuration, you will have to run some tests to get your results validated, depending on your goal and interest of the calculation or simulation.
use batch mode to run an unsteady case | PaulineP | FLUENT | 9 | April 4, 2019 08:18 |
[snappyHexMesh] Editing the motorBike case, loading diffirent .stl | btgyd | OpenFOAM Meshing & Mesh Conversion | 1 | September 26, 2011 17:24 |
Centrifugal Fan Case Study Results Required using CFX | kambireddy | CFX | 0 | October 8, 2010 05:46 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Aero study for symmetry case | Nevur | FLUENT | 2 | September 28, 2005 01:38 |
