channel flow..
Old   July 14, 1998, 00:22
Default channel flow..
R.D.Prabhu
Hello everybody,
I am developing a code for studying 'compressible convection ' in microchannels.
So far ( last three months) I have managed to implement Grahams - modified - two-step Lax-Wendroff scheme.
Now as a validation check ..I was trying to obtain the velocity - profiles for a fully developed flow down the channel..( including the developing profiles near the entrance..)
Can I expect such profiles as a limiting case of my code for fully compressible channel flow..? If yes then should the density fluctuations be kept minimum..? ( and take isothermal case..?)
Besides I am also faced with the problem of handling the entrance /exit for my code ..( should I use any extrapolation to update the grid-points at the inlet/outlet ) any comments/ suggestions are welcome ..
Prabhu
wallHeatFlux for heated walls in laminar channel flow svens OpenFOAM Post-Processing 0 June 20, 2009 20:33
Channel flow set up Jung Main CFD Forum 2 November 21, 2007 06:51
The initial condition for turbulence channel flow Ma Jianfeng Main CFD Forum 1 April 20, 2005 03:50
Stabilizing turbulence equation in channel flow Biga Main CFD Forum 5 March 22, 2005 20:06
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
