on Boundary Condition for P' equation
Old   August 23, 2001, 11:31
Default on Boundary Condition for P' equation
Abhijit Tilak
Hi friends,
I am solving Visc. Incomp flow. in a curved channel using SIMPLE. My outlet is sufficiently far from the bend region. I am specifying uniform pressure at exit (It's known) . I have no Idea what boundary condition to give on Pressure correction ie P'. Can anyone throw some light.
Thanks
Abhijit.
Old   August 23, 2001, 12:10
Default Re: on Boundary Condition for P' equation
Frederic Felten
hi there,
i think that the simplest BC you can choose for the pressure is just: dP/dn = 0 where n is the normal direction to the boundary.
sincerely,
Frederic Felten.
Old   August 23, 2001, 12:38
Jim Park
I don't know SIMPLE in depth.
With that warning, can I guess that, if you know P at the outlet, the correction P' at the outlet should be zero?
Old   August 25, 2001, 03:58
Jongtae Kim
Hi.
If you know pressure on exit boundary, you can use the pressure BC as you said.
Usually pressure is updates as p^(m+1) = p^(m) + p'
here m is iteration number.
If pressure is fixed, p'(pressure correction) is zero. That means Dirichlet BC is used at the boundary for pressure correction equation.
how to set an equation as a boundary condition in phoenics? mukut Phoenics 0 June 21, 2010 07:11
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
Poisson equation for pressure homogeneous boundary condition RenardP Main CFD Forum 1 July 13, 2009 10:01
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 16:53
