what's the difference between "successive substitution" and "segregated" solutions??
Old   December 15, 1998, 16:19
Default what's the difference between "successive substitution" and "segregated" solutions??
wai
I'm a beginner at FIDAP, can someone explain the difference between "successive substitution" and "segregated" solutions??
Old   December 28, 1998, 09:24
Default Re: what's the difference between "successive substitution" and "segregated" solutions??
H Krishnan
The segregated method solves different degrees of freedom seperately (u followed by v followed by w followed by P in fidap). The new value of u is used when the matrix is assembled for v etc.
Successive substitution (and some other methods) assembles and solves the whole set of equations at go, using the old values of the DOFs to assemble the complete matrix. This takes much more memory but is usually faster in terms of iterations.
You can look into the fidap theory manual for more details.
Regards, Krishnan
[General] paraview - plotting difference to reference data joewe ParaView 0 August 30, 2010 18:01
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 22, 2005 23:49
Analytical flow solutions Antonio Main CFD Forum 0 December 14, 2005 15:43
Analytical flow solutions Antonio Main CFD Forum 0 November 15, 2005 17:47
Difference between Lax and MacCormack methods on solutions of 1D problem. AERO Main CFD Forum 2 January 19, 2000 14:36
