January 11, 2002, 16:34 |
B.C's for k and omega
Hi all. I'm currently working on implementing Wilcox's k-w model in my flow solver (PNS based). I'm having a lot of problem with the wall boundary condition - I am working on supersoinc turbulent flow past a flat plate. I have used k=0 at the wall, but my problem seems to be with the omega b.c for the wall. Could anyone suggest some good references/ideas please? Thanks!
January 11, 2002, 17:06 |
Re: B.C's for k and omega
I don't have any references with me here but I struggeld lot with this myself several years ago... If I remember correctly Wilcox has a wall-roughness model which gives an omega value based on a surface roughness. Using this model, with a surface roughness set to something which is essentially "smooth" was the most stable and best boundary condition that I found. I think that this is also what Wilcox recommends - the wall-roughness model is surely described in his book (Turbulence Modeling for CFD).
January 11, 2002, 18:21 |
I did look at Wilcox's wall-roughness condition, but I was wondering if there was any other b.c for a smooth wall. I think I'll try out the rough-wall b.c anyway. Thanks for your input!
January 12, 2002, 04:41 |
If you set the surface roughness paramater (if I remember it correctly Wilcox calls it kr+ or something) to a value well inside the viscous sublayer, say 1, the wall will be smooth - I did a sensitivity analysis on this a long time ago and found that for flows over turbine blades 1 was certainly enough to get a "smooth" blade. It is quite easy for you also to half the kr+ paramater and run againg just to verify that you get the same result.
January 12, 2002, 11:16 |
That's a good suggestion. Thanks again for your reply.
January 14, 2002, 10:18 |
The following reference may be of interest to you.
Antti Hellsten: On the Solid-Wall Boundary Condition of omega in the k-omega-Type Turbulence Models, Technical Report, Helsinki University of Technology, Laboratory of Aerodynamics, Report B-50, Series B, 1998, ISBN 951-22-4005-X. Available on-line from: http://aeropc5.hut.fi/~ahellste/ |
overshooting of Omega in SST komega using simpleFoam | cm_jubayer | OpenFOAM | 2 | June 7, 2020 12:52 |
Boundary Conditions for k omega SST | dancfd | OpenFOAM Pre-Processing | 0 | June 9, 2011 23:25 |
Omega at the wall | sla | FLUENT | 0 | January 10, 2011 04:16 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 05:15 |
Wall function implementation K Omega SSt | cbarry | OpenFOAM | 3 | August 18, 2009 10:09 |
