ROE-flux difference splitting
Old   January 27, 2002, 09:44
Default ROE-flux difference splitting
duanyee
Now I meet with some difficulties in Roe-avarage flux difference splitting solving the fluxs.At sonic points there is wrong entropy pionts.so I have to fix the entropy in Roe scheme.but I don't know how to modify it in the vector systems .ie.for Euler Equations.please give me the method in details.thank you very much !!
Old   February 1, 2002, 04:06
Default Re: ROE-flux difference splitting
Samuel KOKH
If I have correctly understood your problem, a possible answer might be to add a perturbation to absolute values of the jacobian matrix eigenvalues.
Namely, lambda being such eigenvalue, instead of using |lambda|, replace it with sqrt[(1+epsilon)*lambda^2], epsilon being a small parameter you can tune accordingly to your needs.
Old   February 1, 2002, 05:59
Sandro
I think you could also use the Harten and Hyman Entropy fix.
You use for |lambda| = max ( |lambda| , eps)
where eps = max (0 , (lambda(i+1/2)-lambda(i) , (lambda(i+1)- lambda(i+1/2) )
So you only use the correction on expansion shocks and not on compression shocks.
Sandro
Old   February 2, 2002, 00:36
duanyee
Thank you very much I still can't undeerstand the relationship between roe characteristic speed and eiginvalues of Jacobian in the hypobolic conservative systems.for example 1) lamda = f'(u) ??? 2) lamda1<lamda2=lamda3<lamda4 ?? this sequence must be adopted? 3) Roe scheme is apllied to the conservative variables ENO scheme with FVM spatial discretion for me .HOW to modify the lamda without change the FVM? please give me a detailed interpretaion.i am eager for it in my master thesis .thank you
Old   February 2, 2002, 00:38
duanyee
Old   February 2, 2002, 12:09
Samuel KOKH
You are absolutely right. However I just intended to sketch a simple mean to fulfil the thread purpose. I hope I haven't confused anyone with my previous post.
The entropy fix problem is always annoying as, as far as I know, there's no "ultimate entropy fix user guide" around. If anyone has a nice reference, just let me know.
flux splitting emrah Main CFD Forum 3 August 30, 2014 08:53
Flux splitting Dr B.M. Smith (Smith) OpenFOAM Running, Solving & CFD 19 January 9, 2013 04:07
ANY NEWS ABOUT FLUX DIFFERENCE SPLITTING METHODS dinonettis OpenFOAM Running, Solving & CFD 1 June 29, 2008 02:28
About the Flux splitting method maximus Main CFD Forum 0 February 24, 2006 00:05
Flux vector splitting of Inflow/outflow BC Quain Tchew Main CFD Forum 4 March 25, 2002 19:43
