unstructured mesh data structure for FVM
Like Tree1Likes
  • 1 Post By J. Kim
Old   February 6, 2002, 21:20
Default unstructured mesh data structure for FVM
J. Kim
Dear all,
I am looking for an efficient way to extract cell->node connectivity from face->cell and face->node connectivities.
Cell->node connectivity has node(vertex) numbers forming each cell.
Fluent's Gambit exports mixed element mesh data with face->cell and face->node connectivities only. But my fv solver and post-processing code require cell->node connectivity.
Any comments are welcome. Thank you.
ssh123 likes this.
Old   February 6, 2002, 21:47
Default Re: unstructured mesh data structure for FVM
Ma
There is a way here, but I am not sure if it's efficient enough:
(1) Looop faces: extract the face->cell information to cell->face information.
(2) Loop cells: get the cell->vertex information based on cell->face and face->vertex.
I am glad to hear some other more efficient way.
Ma
Old   February 9, 2002, 14:45
Madhukar M. Rao
Invert the face->cell mapping to get the cell->face mapping. Then you can proceed to write the cell->node mapping. You may need to remove duplicate entries in the cell->node mapping. The simplest way is to use an array to carry a flag for duplicated nodes. You can also use a set if you prefer.
If your fv solver expects the nodes to be in a certain order, then the problem is a little more difficult. You will have to sort the cell->face mapping based on the way the faces are connected to each other. Once the cell topology can be inferred from the cell->face mapping, the nodes can be written out in whatever order the fv solver expects.
It should be an interesting exercise.
Good luck,
Madhukar
Old   February 17, 2002, 02:43
Praveen Chandrashekar
See the recent book by Rainald Lohner Applied CFD Techniques: An Introduction based on Finite Element Method.
unstructured mesh phoenics user Phoenics 26 March 22, 2012 12:17
How to control unstructure mesh data susan Siemens 3 April 7, 2008 12:13
Structure or unstructured mesh Nikos Siemens 2 November 9, 2006 18:35
Data Structure for the unstructured finite volume method Anthony Main CFD Forum 4 February 2, 1999 19:24
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
