Flow Past a Cylinder
Old   March 28, 2002, 06:11
Default Flow Past a Cylinder
Annie
In the below paper, Guang-Shan Jiang and Chi-Wang Shu give an example of ENO and WENO handing non-rectangular domain. i.e. flow past a cylinder.
`Efficient Implementation of Weighted ENO Schemes', J. Comput. Phys, 126, 202 (1996).
The problem is initialized by a Mach 3 shock moving toward the cylinder from the left. But this paper doesn't give the state of the flow before the shock (\rho,u,v,p).
I am trying to do this case now. If you can give me some suggestions or some references, I will appreciate very much.
Annie
Old   March 30, 2002, 23:30
Default Re: Flow Past a Cylinder
Praveen Chandrashekar
If you know the state of the gas one side and you know the shock speed, you can calculate the state on the other side from the jump conditions
[F] = s[U]
Old   March 31, 2002, 00:02
Annie
Unfortunately, I don't know the state of the gas one side. That paper only says a Mach 3 shock moving from left to right.
2D modelling of flow past a rotating cylinder pds24 Main CFD Forum 1 August 21, 2015 10:50
CFD help: flow past cylinder harsha00711 Main CFD Forum 1 December 24, 2010 21:19
Flow past cylinder harry FLUENT 0 May 29, 2006 06:18
meshing for flow past a cylinder karthik FLUENT 1 July 15, 2005 06:17
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
