Fortran: Seeking data in files.
Old   April 26, 2002, 11:08
Default Fortran: Seeking data in files.
cfd guy
Hi people,
I was wondering if I can extract a specific data from a file using a subroutine in FORTRAN. Which command can I use? Below, I'll show a simple example. Suppose that I have a file, TEST.DAT, and this file has the following lines:
. . . . . VAR = 10 VAR2 = 50 /* COMMENT */ TIME = 100 VAR3 = 30 . . . . .
I want to extract the value from TIME variable. How can I do that? Important, this variable doesn't remain constant in a certain line. Is there any function in FORTRAN that I can seek this characters ('TIME = ') and then READ it (100) in my subroutine? I hope anyone of you can help me.
Kind regards, cfd guy
Old   April 27, 2002, 01:20
Default Re: Fortran: Seeking data in files.
Bob
It depends entirely on which Fortran compiler you are using. Each has their own string handling intrinsics. Try reading the manual or help file of yours under strings or intrinsic functions.
Old   April 27, 2002, 13:09
cfd guy
Thanks Bob,
I use Visual Compaq Fortran 6.5 under NT. I took a look at manuals several times and I didn't find a specific command for seeking strings in files.
cfd guy
Old   April 28, 2002, 08:02
andy
Native Fortran is good enough to handling this sort of thing directly. Read each line into a character buffer and then test/read it for whatever you want. Something like below should work (adding declarations and removing possible typos and the mangling by html).
1000 read( dn, '(a)', iostat=ierr ) buffer
if ( ierr .eq. 0 ) then
if ( buffer(1:6) .eq. 'TEST =' ) then
read( buffer(7,'(i8)' ) time
else
goto 1000
end if
end if
Of course, you could generalize it a bit and put it in a function or subroutine. (Curiously, this was one of the in-class exercises I used to set students many years ago when teaching Fortran.)
Old   April 28, 2002, 09:55
peter.zhao
CFD guy:
You can use the namelist input, which can be found in help file!
Good luck!
Old   May 3, 2002, 12:03
cfd guy
Thank you very much andy,
Your native fortran suggestion worked very well.
Old   May 23, 2002, 22:30
Default How to do it in Matlab?
wen long
Then how to do it in Matlab? Thanks!
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
grid data to be read by Fortran code seckin FLUENT 0 April 19, 2003 14:03
