prescribed inflow conditions
Old   January 29, 1999, 04:35
Default prescribed inflow conditions
Thorsten
Hello everybody!
Who could recommend on the prescription of inflow boundary and/or initial conditions for 3D turbulent open-channel flow? Who has made experiences with different conditions? All suggestions in any form (formulas, references etc.) are welcome. Thank you very much in advance for any effort.
Cheers, Thorsten
Old   January 29, 1999, 13:47
Default Re: prescribed inflow conditions
John C. Chien
I think, you are talking about the non-uniform inlet condition. There are several approaches: (1). extend the inlet location in the upstream direction, and specify a condition there. ( you hope that when the flow arrives at the real inlet station it will behave in the way you like.) (2). specify the boundary layer thickness, and prescribe the profiels analytically using available data. ( you can control the non-uniform profiles.) ,(3). compute the section of the flow upstream of the inlet separately. ( this way, you have some ideas about the flow at the inlet station.), (4). measure the flow properties at the inlet station and use it in the computation. (if the flow you are going to calculate does not exist , then this method is useless.). I like your question, because this will tell who is the CFD mechanics and who is the CFD engineer. The proper selection of the computational domain and the associated boundary conditions require the real understanding of the problem itself.
Old   January 29, 1999, 15:03
Thorsten
Dear John,
Thanks for your response. Yes you are right possibility No.1 is difficult. I will try a combination of 1. , 2. and 3. first using the logarithmic velocity profile law and having Ushear and Umean computed previously with a 1D calculation. Unfortunately No.4 is not always feasible and very time consuming in addition. I hope this might be worth a try. So thanks again and have a nice day. Best wishes Thorsten
k-w turbulent model and inflow boundary conditions vaina74 Main CFD Forum 6 April 26, 2010 06:03
Inflow turbulence conditions ghost12 Main CFD Forum 0 April 7, 2010 10:09
Turbulent Inflow Conditions ali OpenFOAM Running, Solving & CFD 2 July 9, 2009 09:55
How to set the inflow conditions of turbulent BL? CFDer Main CFD Forum 2 March 8, 2006 09:05
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 12:14
