Law-of-the-wall and Wall functions
Old   September 11, 2002, 04:50
Default Law-of-the-wall and Wall functions
Bo Busk Jensen
Hallo All
A very simple question. Using standard k-e models the near-wall region should be described by....
1) is it described by a wall function that use what is stated in the law-of-the-wall
2) is it described by the law-of-the-wall
Are wall functions a general term for different ways of treating what is inside y+ 30, where the law-of-the-wall is one way to do it??
Regards
Bo
Old   September 11, 2002, 07:29
Default Re: Law-of-the-wall and Wall functions
Abhi
hi i can probably answer you but i didn't understand ur questin. Can you please clearly tell again?
Old   September 11, 2002, 08:13
Bo Busk Jensen
Hallo All
1) a wall function that use the law-of-the-wall
2) the law-of-the-wall
Are wall functions a general term for different ways of treating what is inside y+ = 30??
Regards
Bo
Old   September 11, 2002, 09:06
Jim Park
My understanding is that:
1. "Wall functions" are a way of modeling the complex turbulent fluid behavior very near a solid wall that bounds a turbulent flow, and
2. The "law of the wall" is the result of many careful measurements of one configuration of turbulent flow, the flow over a flat plate.
So, there is the general technique and a particular example.
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
help with wall functions Nick Georgiadis Main CFD Forum 10 January 17, 2017 10:03
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
