Mesh for Cylinder-Piston?
Old   December 4, 2002, 00:55
Default Mesh for Cylinder-Piston?
Serkan Cetin
I try to simulate a flow in a cylinder gap of 0.2 mm(!) with a piston jump stroke of up to 30 mm. Has any body experiences in succeeding in this kind of example? Also what should be prefered ?Mesh layer addition& removal or squeezing the layers of the mesh as the piston approaches the cylinder bottom. As I heard STAR-CD allows to add/remove cells in mesh motion... are there any other CFD packages supporting this feature?
Thanks and regards from a new begginner..
Old   December 4, 2002, 08:39
Default Re: Mesh for Cylinder-Piston?
cfd guy
Hi, I'm using CFX-TASCflow to simulate an IC engine. The code squeezes/expands the cells as the piston moves. All I can say that works but it is extremely hard to control the moving nodes and I didn't find a way to close completely the gap between the valves and the cylinder piston because I can't have elements of null volume. Thus, I believe the addition/removal cells feature is the best approach for this case. Like you I know that Star-CD does this feature. What about KIVA?
Regards, cfd guy
Old   December 4, 2002, 09:55
cfduser
Hi all
KIVA definitely can do this being created for the primary purpose of simulating in-cylinder flows.
A number of example grids can be found on their site.
HTH
Old   December 4, 2002, 11:44
Joern Beilke
Have a look at FOAM (www.nabla.co.uk). It is free for academic use.
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 09:13
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
