k-e in laminar flow
Old   May 15, 2003, 06:13
Default k-e in laminar flow
Jake
Hi.
I was wondering. Can a turbulent model like (eg.) k-e or RSM calculate a laminar flow correctly?
If no, what do one do in a case where there are both laminar and turbulent flow zones?
Thanks.
Old   May 15, 2003, 07:17
Default Re: k-e in laminar flow
Tom
You can't use k-epsilon to do laminar flow. If you have regions of both laminar and turbulent flow then you need a method for predicting the transition point as well as a method of damping the turbulent contributions (so that they are zero in laminar flow). I don't know of any schemes that can do this in general flow configurations. Predicting flow transition is still very much an open problem and is an active area of research.
Old   May 15, 2003, 09:27
Jake
Ok. Thank you for your answer.
Old   May 16, 2003, 04:21
Holidays
Some codes can deal with transition alledgedly, but in fact you supply the transition region a priori as far as I understand and the topic of a self-determining transition is indeed an active field of research.
Old   May 20, 2003, 12:09
James
The Wilcox book (Turbulence modeling for CFD) gives a good overview of transition modelling with the k-epsilon and k-omega models.
alternatively, try:
D.C. Wilcox "Simulation of Transition with a Two-Equation Turbulence Model" AIAA Journal, Vol 32, No. 2, February 1994.
this is mainly about the k-omega model but does give a good insight into the problems with two-equation models and transition.
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 17:35
Can I use turbulent model to solve a laminar flow? nikhil FLUENT 5 February 1, 2011 10:42
How to enforce laminar flow while using k-e Grzegorz Kondora FLUENT 0 January 28, 2009 10:35
grid for laminar flow kim FLUENT 2 April 4, 2002 02:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
