Best way to export from Pro/E to ESI
Old   April 20, 2009, 14:07
Default Best way to export from Pro/E to ESI
Martin
SBR_Martin is on a distinguished road
I am an undergraduate aerospace engineering student. For one of my classes, I need to give a 5 min tutorial on the best way to export CADs from Pro/E to CFD programs. I chose ESI because that is the program used at my school. I have talked to several people including professors and nobody has given me the same answer twice. It seems there are many ways to do this and nobody can tell me what the best way is.
Questions:
What type of file should the CAD be exported as from Pro/E?
Is there a particular program that should be used to fix the surfaces like CADfix in the exporting process?
Is there a better program than ESI that requires a simple and standard exporting process from Pro/E?
Be forewarned my knowledge in CFD is mostly about the Navier–Stokes equations and how to actually use the various programs is very minimal. Any information would be welcomed.
Thank you,
Martin
SBR_Martin is offline   Reply With Quote
Old   April 20, 2009, 14:13
Andrew
mettler is on a distinguished road
I always export SAT files. I am not a big fan of ProE, so if I am stuck with a ProE file the first thing I do is move it to SolidWorks. Still, I believe fluent has a program that is useful for the import of files. I know they have one for SolidWorks, and if I remember correctly they have one for ProE as well. Fluent heals geometry when you import it, but you still have to check it over. I have had good experiences with it, but there is a learning curve. Anything beats drawing in gambit tho.
mettler is offline   Reply With Quote
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 09:45
export data at nodes Meenu FLUENT 1 December 30, 2011 01:24
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
How to export Pro/E 2001 Part drawings to Gambit Imran Shaban Bhatti FLUENT 2 March 27, 2006 19:33
Importing I-DEAS unv file hbetb FLUENT 1 August 10, 2001 13:22
