August 27, 2003, 13:09 |
Energy equation convergence problem
I have asked this before but have not found a good answer. I have to solve the energy equation along with the momentum and continuity equation for a solidification problem. The problem is that at certain points the energy equation does not converge. Also I am running a multi-component mixture so I have mushy zones and it is impossible to use the expressions used in the literatue for updating the enthalpy. What I am doing at this moment is updating the enthalpies in the source term of energy equation based on the availble temperature. Also I have to under-relax the temperature at each iteration. But for some strange reason the convergence fails after some time. I have run the code for single phase and it was ok. Can anybody give me a hint or help me with some ideas?
Thank you for your considerations. |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Convergence problem in energy equation | majidtaleby | FLUENT | 0 | June 22, 2010 16:32 |
History Convergence: Graphical problem | Bedotto | Fidelity CFD | 1 | March 17, 2010 23:40 |
CONVERGENCE PROBLEM - oil boiler | MM | FLUENT | 1 | February 15, 2007 05:24 |
how to disable energy equation for for non-newton | yueroo | FLUENT | 2 | April 3, 2001 22:11 |
