stability and accuracy
Old   September 16, 2003, 02:58
Default stability and accuracy
rvndr
Hi I am beginner and solving simple second order Heat conduction equation using FTCS and CN method. When can I say, the solution is both stable and accurate, only stable ,and only accureate ? What is the relation between stability and accuracy ?
Thanks in advance
regards ravi
Old   September 16, 2003, 05:27
Default Re: stability and accuracy
P. Birken
I don't think that there is a definition for accuracy. The important realtion is that (under some conditions): Stability + Consistency <=> Convergence. You should look those terms and their meaning up in a text book on numerical analysis for ODEs. Essentially it means that if your scheme is unstable, it is also divergent and dependent on what order of consistency you have, your order of convergence increases. Sort of ;-)
Aerodynamic Stability Derivatives Andrew Clark FLUENT 1 November 23, 2021 20:19
Any questions about Runge-Kutta methods Runge_Kutta Main CFD Forum 33 September 9, 2019 16:32
error when solving gamma equation? zhajingjing OpenFOAM 1 April 27, 2010 03:32
effect of order of temporal accuracy zonexo Main CFD Forum 4 August 14, 2006 00:36
Semi-implicit Runge-Kutta Bobby Main CFD Forum 10 August 5, 2005 15:43
