Need help on KIVA-3V spray output
Old   October 11, 2006, 07:39
Default Need help on KIVA-3V spray output
Mr Amida Oluwole
Hi,i make my computational work with KIVA-3 code but i am changing to KIVA-3V for spray simulation and combustion modeling,however,i am having problem with the spray model.I set the nozzle exit velocity to 250m/s and the numvel to 1 but the result is outputing a velocity less than 250m/s at the nozzle exit.I will be glad if anyone can advise on this problem of mine.
Thanks as your advise will be wonderfully helpful.
Amida.
Old   November 8, 2006, 07:15
Default Re: Need help on KIVA-3V spray output
ulf
KIVA calculates it's own injection velocities with the given spmass (mass of injected fuel for the whole number of nozzles), the fuel density, the injection duration, the discharge coefficient and thee nozzle area of one nozzle hole. you can check it by yourself with fuel_mass=injection_velocity*injection_duration*Ar ea*fuel_density
Old   November 13, 2006, 20:33
Mr AMIDA OLUWOLE
Thank you very much for your advice, however, the problem is when using a velocity table, i understand that KIVA-3V calculates the right velocity with respect to the amount of fuel(tspmass) been injected. But my problem is the fact athat i want to inject fuel with a single velocity and also will like to know if you did experience the same problem i am trying to solve now, i mean the breakup model (rtaylorerc and waverc). Droplets are not atomize into smaller droplets as injection curve increases. I used a sine curve for my injection profile. Please advice
Old   January 3, 2012, 10:47
Exclamation examples for kiva 3V
ninguna
mel021184 is on a distinguished road
Hi, I need examples for kiva 3V.
non engine application.
someone who can help me?
someone who has worked with kiva 3v?
I'm trying to simulate a spray impacting on a surface.
mel021184 is offline   Reply With Quote
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 12:30
help, error spray simulation in contant volume chamber with kiva toto Main CFD Forum 0 June 8, 2009 09:52
[Other] Output Format of MetaMesh t42 OpenFOAM Meshing & Mesh Conversion 0 August 3, 2007 04:28
spray injection mmacrb FLUENT 0 January 10, 2007 04:57
PDF - conserved scalar approach in KIVA vega Main CFD Forum 0 July 5, 2005 02:49
