convergence analysis for viscous problems
Old   September 22, 2009, 04:19
Default convergence analysis for viscous problems
Shyam
shyamdsundar is on a distinguished road
I am trying to benchmark my higher order DG code for viscous problems. I devised a new method of representing the viscous flux at cell interface and am required to establish the order of accuracy of the proposed scheme.
I took the standard test case of isentropic vortex evolution problem as the initial setup and am trying to estimate the error as the difference between the solutions (at t=5) of the current grid and the refined grid. For example, if I have grids G1, G2, G3, the error for G1 would be |Q1-Q2| where Q is the solution on the grid. The error for G2 would be |Q2-Q3| and so on. Is this the right way to estimate the grid convergence if we do not know the analytical solution?
When I do the above test, I get acceptable grid convergence results. I am just wondering if it is the right way to do...
Shyam
shyamdsundar is offline   Reply With Quote
Old   September 25, 2009, 13:54
Josh
jstults is on a distinguished road
That approach should give you the right order of convergence estimate (slope of log(err) v log(dx)), but won't give you an estimate of the constant multiplier out front (intercept of log(err) v log(dx)). To get that you would want to do something like: |Q1-Q4|, |Q2-Q4|, |Q3-Q4|, where the grid for Q4 is much finer than 1,2 and 3, but 1,2 and 3 are still in the asymptotic range. So you're basically treating Q4 as your analytic solution.
Not many people care about estimating the constant on the truncation error though.
jstults is offline   Reply With Quote
Fluent Convergence Problems Vidya FLUENT 24 January 1, 2016 13:01
Convergence problems... need help urgent!! HSeldon FLUENT 1 March 15, 2007 01:04
Convergence Problems Carlos FLUENT 0 March 12, 2007 02:44
Convergence problems Simone Siemens 5 June 29, 2005 10:48
Convergence problems Olivier Macchion CFX 4 January 22, 2003 01:57
