Supersonic fluid flow patern in a dip
Old   July 26, 1998, 20:17
Default Supersonic fluid flow patern in a dip
Daniel Vahidi
I'm searching for some paper(s) posted on the web specifically about Supersonic Fluid Flow in Cavities/Dips which include(s) some pictures about the phenomenon. I haven't found any URL address so far. If have any idea about that, please inform me. Thank you.
Old   July 28, 1998, 18:47
Default Re: Supersonic fluid flow patern in a dip
John C. Chien
The formal subject name maybe :" Supersonic Flow over a Cavity ". The flow inside the cavity normally is subsonic. If this is the case. Then try the AIAA Journal. Supersonic flow over a cavity is usually un-steady, which is created by the shear layer/ supersonic flow interaction. A shot in this case does not give you the whole picture. (If this is not the case, I would like to know how you create supersonic flow in a cavity.)
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
supersonic flow Steffen FLUENT 6 October 26, 2015 13:06
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Determine time taken for fluid flow mapuma FLUENT 0 March 4, 2010 11:16
Fluid flow will affect with different diffusivity? tseo FLUENT 0 January 17, 2005 01:41
