Memory stack-Fortran vs Windows XP
Old   February 5, 2004, 12:09
Default Memory stack-Fortran vs Windows XP
Mikel A.
Hi, I have been running our code up to 1.5GB RAM size in my computer. It has 2.56GB RAM available. I have tried unsuccesfully to run a 2.06GB simulation and Windows XP gives the error: it is not a win32 application. Does anyone know how to make Windows XP go over 2GB RAM?
Thanks!!
Mikel Alonso
Old   February 5, 2004, 13:28
Default Re: Memory stack-Fortran vs Windows XP
Raul
Hola
What's the (company) name of the Fortran compiler your're using in Windows XP?
/Raul
Old   February 5, 2004, 18:23
Marcus Lobbia
If I remember correctly, Windows will only allow 2GB max for a single process... you may have to use Linux or a 64bit CPU/OS to exceed this limit (e.g., maybe try a Athlon 64 / Opteron running 64bit Linux, or a 64bit Sun/HP Unix workstation).
Old   February 6, 2004, 02:31
Mikel
Compaq Fortran, 6.6b
Old   February 6, 2004, 02:33
Mikel
Thanks Marcus. I am going to use Linux. It seems like the best short term solution.
Old   February 10, 2004, 08:15
Steve
I had the same problem and I migrated on Linux !!
Steve
memory ms visual fortran 6 vadim Main CFD Forum 0 December 20, 2008 13:01
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
Integer stack memory size Twiti CFX 2 December 22, 2004 07:38
Stack frame size, Origin 2000, fortran, a question. Sergei Chernyshenko Main CFD Forum 4 February 22, 1999 14:24
