Is there an alternative method for TDMA (Thomas algorithm)
Old   January 18, 2010, 01:29
Default Is there an alternative method for TDMA (Thomas algorithm)
katakgoreng is on a distinguished road
I'm using TDMA to solve for the SIMPLE algorithm. For small grid, the TDMA converged quite fast but for large grid the convergence rate is killing me. Is there an alternative to TDMA that is simple to code and give faster convergence apart from Gauss elimination (consume alot of memory)?
katakgoreng is offline   Reply With Quote
Old   January 18, 2010, 12:03
DoHander is on a distinguished road
Try an iterative solver - check lapack library for example, you can find some hints about what solver you can use for a linear system in the book of Peric.
BTW TDMA is just a specialized Gauss elimination for tridiagonal system.
Do
DoHander is offline   Reply With Quote
Old   January 18, 2010, 12:29
Thanks alot..really appreciate your response..
Old   January 18, 2010, 23:33
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
I am slightly puzzled by the use of the term "convergence"... The Thomas algorithm is a direct solver (i.e not iterative), as pointed out.
I think that the Thomas algorithm is part of an algorithm that itself takes a while to converge (ADI, under-relaxation, treatment of non-orthogonal terms, other). You may want to have a check of the algorithm as well.
Hope this help.
Julien
julien.decharentenay is offline   Reply With Quote
Old   January 19, 2010, 06:23
Default Krylov with Schur-complement preconditioning
jed
Jed Brown
jed is on a distinguished road
Classical SIMPLE is really not a very robust algorithm, a much better approach is to discretize implicitly in time and solve the linear systems with a Krylov method (like GMRES) preconditioned with a Schur-complement scheme. For example,
@article{elman2008tcp,
  title={{A taxonomy and comparison of parallel block multi-level preconditioners for the incompressible Navier-Stokes equations}},
  author={Elman, H.C. and Howle, V.E. and Shadid, J. and Shuttleworth, R. and Tuminaro, R.},
  journal={Journal of Computational Physics},
  volume={227},
  number={1},
  pages={1790--1808},
  year={2008},
  publisher={Academic Press}
As for software, Lapack offers only dense/banded direct solvers (contrary to DoHander's suggestion). I recommend using PETSc because it offers a great deal of composability so that you can try very exotic schemes with low effort (usually without touching your source code).
jed is offline   Reply With Quote
Apply Multigrid method to SIMPLE Algorithm yang Main CFD Forum 1 February 25, 2006 11:28
Multigrid method for SIMPLE Algorithm yang Main CFD Forum 2 February 23, 2006 17:11
SIMPLE ALGORITHM approach-Multigrid method Skumar Main CFD Forum 0 November 14, 2005 14:16
SIMPLE Algorithm & Conjugate Gradient Method Abhijit Tilak Main CFD Forum 7 March 20, 2001 00:01
Thomas Algorithm Testing Out of Ideas Main CFD Forum 3 February 8, 2001 22:45
