Design & analyses of wind turbines final year project, please help!!!
Old   March 2, 2010, 13:27
Exclamation Design & analyses of wind turbines final year project, please help!!!
Mag
heavymag is on a distinguished road
Hi
I am a Mechanical Engineering student from UK.
I am doing my final year project on Analysis and Design Wind Turbines. I need to analyse the blade design by using CFD.
I am told to use Fluent, but I found out that XFOIL or XFLR5 is also a very good program for that.
Could you please tell me which one would you go for (or both), and what is the best way to analyse a wind turbine blade on CFD. In Fluent I know that if you are setting up a 3D wind turbine problem you need to use the MRF (moving reference frame) right? Can you use the MRF for 2D analyses as well?
I am going to analyse firstly 2D and then if possible I would like to build a 3D model of the wind turbine.
I thought of modelling it on Pro Engineer and then importing onto Gambit by saving it as a IGS file.
Do you know anything about 3D meshing and how is the easiest way to do it?
Any help is greatly appreciated
Many thanks
heavymag is offline   Reply With Quote
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
