May 18, 2004, 16:59 |
Gambit mesh export
Hi ALL,
I was hoping that somebody could answer this question. Basically I generated a mesh in Gambit and now I am trying to output it into a neutral format (Generic neutral) so that I can read the same mesh into CFX-Pre through the PATRAN Neutral format. I cannot do it. Is there any other way I can export the gambit mesh so that I can read it into CFX-Pre?? Thanks Satya |
May 26, 2004, 17:06 |
Re: Gambit mesh export
Is neutral format means the format with extension .neu? If yes, I've been always exporting mesh from GAMBIT to .neu format, and it doesn't show any problem if I choose solver in GAMBIT appropriately. I choose POLYFLOW as solver in GAMBIT; and I remember in last version of GAMBIT I used other solver which doesn't give .neu in the current version so I switch to POLYFLOW.
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Export Edge mesh in Gambit | mecipema | ANSYS Meshing & Geometry | 3 | February 16, 2011 08:20 |
Problems with gambit mesh | lions85 | FLUENT | 2 | August 28, 2009 19:05 |
export or convert gambit mesh to CGNS | zaidun | FLUENT | 6 | April 20, 2006 04:48 |
GAMBIT merge and export mesh | sean | FLUENT | 4 | March 8, 2001 07:50 |
