May 14, 2010, 13:44 |
Help on induced drag in VLM
Aneesh Goly
I am doing analysis of ocean current turbine using vlm. i computed lift force and Can anyone please let me know how to calculate the induced drag (or any reference). Thanks Aneesh |
August 25, 2010, 05:07 |
César Vecchio
If you where able to calculate lift force then induce drag is pretty much the same. I suppose you calculated the force on each panel by:
Fi=gammai*rho*V*bi (Kutta's formula) Now, as Fi is a force it has three components in x,y,z respectively, usually in body axes. So: Fx=sum(Fxi) Fy=sum(Fyi) Fz=sum(Fzi) Then to convert those total components to wind axes simply apply a rotation matrix (Euler angles) which depends on attack and yaw angles solely: [Di,C,L]'=[rotation matrix]*[Fx,Fy,Fz]' Di is induced drag, C is lateral force and L is lift. To obtain coefficients divide each of them by q*S. If you're not happy with my answer, you can check the books by Jack Moran (provides sample VLM code) or the good ol' Katz & Plotkin. You can also check the source code of Tornado, AVL, VLMpc or VorStab, they are all open source VLM codes, and reliable. |
June 7, 2019, 16:19 |
Zack
Rep Power: 10 |
That would give you a force perpendicular to the freestream and you wont get drag force but thrust force,.
cdi, induced drag, vlm |
induced drag | Amir | FLUENT | 0 | March 5, 2009 10:08 |
Help me please, A.S.A.P ( about induced drag ) | deus | CFX | 0 | June 22, 2008 09:33 |
Induced drag in panel method | andre | Main CFD Forum | 1 | March 8, 2008 10:58 |
Induced drag from N-S flow-field | Jarmo Monttinen | Main CFD Forum | 0 | January 15, 2004 18:10 |
Induced Drag Reduction | Erich | Main CFD Forum | 1 | March 22, 1999 04:39 |
