June 7, 2010, 12:54 |
mesh converter in KIVA 4
Rep Power: 16 |
Hi guys,
I'm a kiva 4 user and i'm getting some problems with the mesh converter supplied with KIVA 4 package. The problem I got is related to an odd behavior once I create the mesh using k3prep and try to convert the file itape17 into kiva4grid. When I do that, I'm always able to get the mesh but sometimes that mesh doesn't work at all. I mean you can use that mesh, you can run the code in it, but when you try to visualize the outcomes in Tecplot, the file can't be loaded. The test i was doing to check this out was based on using the original mesh (itape 17) in KIVA 3 and and the converted one in KIVA 4. What I got was that the original mesh works, but the converted one doesn't, weird right? has anyone had the same problem? would i need to check out anything before converting the mesh? thanks in advance |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
kiva mesh generation-es-ice possible??? | mepgzzi | Main CFD Forum | 0 | March 31, 2009 05:34 |
ICEM 10 mesh question | DAK565656 | CFX | 6 | May 8, 2007 12:16 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
KIVA: mesh | sasidhar | Main CFD Forum | 0 | June 30, 2005 12:53 |
