July 23, 2004, 19:50 |
Lax-Wendroff
Can any budy tell me how Lax-Wendroff scheme is implemented for a simple equation?: d(z)/dt + d(f)/dx =0 notice that here f /= c*z, and if yes, c is not a constant. The reason I'm getting serious with it is that, I sense that Lax-Wendroff scheme is originally derived for c=const case, then it doesn't work for non-constant c case as I try to plug the usual formula in text-books into my code. I'm gonna try to rederive Lax-wendroff scheme suitable for varying c cases. Before I go out and do that, I want to know how u guys are actually dealing with it. If everybody just takes it for granted that the textbook lax scheme should work for varying c cases while the formula is derived with const c, isn't that silly? Thanks for your input, Wen |
July 25, 2004, 12:56 |
Re: Lax-Wendroff
I think you are talking about linear version of Lax-Wendroff method. There is a generalization to noliner system of equations known as a two step Richtmyer-Lax-Wendroff method. It works for general f(z) form. See for example LeVeque "Numerical Methods for Conservation Laws."
July 25, 2004, 14:03 |
Re: Lax-Wendroff
Angen:
Thanks, I notised that too. Richtmyer scheme is a two-step method. I'm hesitating on using that for I don't want to use multiple step methods, reason is that my f is pretty hard to compute, i want the calling of it to be minimum. But I'll definite check the reference you gave, Wen |
Difference Between the Oscillations of Lax Wendroff Method and that of Beam Warming | rizwanherl | OpenFOAM Programming & Development | 0 | June 8, 2010 16:08 |
Lax method stability via von neumann analysis | morteza08 | Main CFD Forum | 1 | June 5, 2010 12:43 |
Lax wendroff and Maccormack | prapanj | Main CFD Forum | 3 | November 20, 2007 13:18 |
Difference between Lax and MacCormack methods on solutions of 1D problem. | AERO | Main CFD Forum | 2 | January 19, 2000 14:36 |
CFD Lax Equivalence Theorem? | Amadou Sowe | Main CFD Forum | 4 | November 4, 1999 13:32 |
