July 25, 2004, 07:38 |
Slow flow
What is a good approximation for very very slow flow, a few mm per hour, in a transient stage? Low velocity in a fluid with density similar to that of water. Does any body know about publications on the subject?
July 25, 2004, 08:44 |
Re: Slow flow
Is your Re small? If so, this is Stokes (or creeping) flow, where the convection term is negligible compared to diffusion. In this case the solution is much easier - since convection usually causes most of the modeling difficulties - and the equations become similar in form to the heat conduction equation. I am not sure what is the common threshold for the applicability of this simplification, though - I think it is Re<1, but you should check it for yourself.
July 26, 2004, 17:57 |
Re: Slow flow
Rami. Thank you. Do you know any publication showing classical cases?
July 29, 2004, 18:54 |
Re: Slow flow
Use google and type "stokes flow", you will find tons of them and it is always discussed in traditional fluid mechanics books.
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
Instability and Vortex/roll structure | Z. Zeng | Main CFD Forum | 3 | May 10, 2000 05:18 |
