August 3, 2004, 05:57 |
Setting up the right boundaries
Hello everybody. My problem is: I'm simulation a pipe system after a pump with an outlet of static pressure. I have a fixed pump that I have to use. What kind of inlet boundary should I define with that situation? The pump is not delivering a fixed flow rate or a fixed pressure. Should I define that boundary as a "total pressure"? That value should be quite fixed as the power stays almost the same all the time.
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 04:23 |
LiftDrag utility from v12 to v141 | cfdphil | OpenFOAM Running, Solving & CFD | 2 | December 5, 2007 05:49 |
Ultra high temperature? | bk | Siemens | 2 | July 19, 2005 00:01 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
