How to read files in parallel using fortran and mpi
Old   November 21, 2010, 10:41
Default How to read files in parallel using fortran and mpi
TWB
quarkz is on a distinguished road
I am now trying to read a data file which has about 2000x2000 pts. In the past, when file size is smaller, the file was read by 1 processor and then distributed to the rest of the processors.
However, now the file size has gotten too big for the current memory. I am able to write to the file in parallel using:
DO irank = 0, nprocs - 1
CALL MPI_BARRIER(MPI_COMM_WORLD, ierr)
IF (irank == myrank) THEN
IF (myrank == 0) THEN
OPEN(10, FILE=’output’)
ELSE
OPEN(10, FILE=’output’, POSITION=’APPEND’)
ENDIF
WRITE(10) (outdata(i), i=ista,iend)
CLOSE(10)
ENDIF
ENDDO
I tried to do the same for the reading case but it can't work. Is it possible to read in fortran files by skipping e.g. 20000 values? If it's possible, then I should be able to solve my problem. Btw, I am using fortran binary files.
Thanks
quarkz is offline   Reply With Quote
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 01:55
How to partition cartesian grid for MPI in fortran CF Main CFD Forum 3 January 17, 2008 04:38
how to call C++ function from fortran with MPI kenn Main CFD Forum 1 February 17, 2002 20:39
